[GRASS5] Again Solaris/tar/Makefile problem
Markus Neteler
neteler at geog.uni-hannover.de
Wed Apr 18 10:09:46 EDT 2001
On Wed, Apr 18, 2001 at 03:30:33PM +0200, Federico Ponchio wrote:
> Hello,
> one of the problems on Solaris tar is that options MUST go first
> (and i think it depends on getopt in the libraries which behaves
> strangely). I installed Grass on a solaris, and solved the tar problem
> that way (just moved options at the beginning).
> Hope that helps.
> Federico.
Hi Federico,
would you be so kind a send a "diff" to either me or Justin?
Thanks,
Markus
> On Fri, 13 Apr 2001, Glynn Clements wrote:
> > Markus Neteler wrote:
> > > find attached a report on tar/Makefile/Solaris. This was
> > > reported before, I feel, we have ignored it.
> > > Does anyone have a safe solution?
> > Is it not safe to simply omit the trailing slash?
> > If it isn't, they I guess that we would need to use
> > find ... | tar cT ...
> > BTW: is tar's "C" switch non-standard?
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
