[GRASS5] Again Solaris/tar/Makefile problem
Federico Ponchio ponchio at ruffini.dm.unipi.it
Wed Apr 18 09:30:33 EDT 2001
Hello,
	one of the problems on Solaris tar is that options MUST go first
(and i think it depends on getopt in the libraries which behaves
strangely). I installed Grass on a solaris, and solved the tar problem
that way (just moved options at the beginning).
	Hope that helps.
	Federico.
On Fri, 13 Apr 2001, Glynn Clements wrote:
> Markus Neteler wrote:
> > find attached a report on tar/Makefile/Solaris. This was
> > reported before, I feel, we have ignored it.
> > Does anyone have a safe solution?
> Is it not safe to simply omit the trailing slash?
> If it isn't, they I guess that we would need to use
> 	find ... | tar cT ...
> BTW: is tar's "C" switch non-standard?
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
