[GRASS5] make or genu make
Andreas Lange
Andreas.Lange at Rhein-Main.de
Wed Apr 18 06:06:12 EDT 2001
to be on the safe side, go with GNU make. There may be features required
that unix make does not provide. But it may depend on which compiler you
use. (gcc with GNU make, else try the make from your system?)
Markus, if GNU make is required/recommended, we should put another note
into the REQUIREMENTS file!
cu,
Andreas
Robert Lagacé wrote:
> Does GRASS require genu make or it can use UNIX make?
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
