[GRASS5] v.in.arc: import files
Michel Wurtz mw at teledetection.fr
Wed Apr 18 01:59:30 EDT 2001
David D Gray wrote:
> Some changes to v.in.mif now mean it should open a file given any valid
> unix path name.
> ie. Supply for input a full path, relative path or just a file name of
> *.mif, *.mid or just the base name *.
> Default output is the base name of the file, if `output' is supplied it
> over-rides this. So output would always be an optional parameter.
> Can I suggest this as appropriate default behaviour for any external
> file import?
I think v.in.arc should be modified in that way... m.in.e00 doesn't ask
for an output name, so this could be added...
Michel WURTZ - DIG - Maison de la télédétection
               500, rue J.F. Breton
               34093 MONTPELLIER Cedex 5
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
