[GRASS5] GRASS Monitor
Malcolm Blue
mblue at nb.sympatico.ca
Tue Apr 17 23:46:13 EDT 2001
The best place to look to get started is:
http://www.geog.uni-hannover.de/grass/firsttime.html
This has links to sample data, tutorials and other useful information, plus has
some basic information to get you started.
Enjoy,
Malcolm
ja id wrote:
> hello ,
> i had been download grass5 in linux platform but it can't running completely
> .it wanna location,mapset and database...what would i do..and how i'm going
> to do...
> >From: "Eric G. Miller" <egm2 at jps.net>
> >Reply-To: grass5 at geog.uni-hannover.de
> >Subject: Re: [GRASS5] GRASS Monitor
> >Date: Tue, 17 Apr 2001 18:27:53 -0700
> >On Tue, Apr 17, 2001 at 02:43:22PM -0300, Bob Covill wrote:
> > > Hello,
> > > This is probably a question for Eric.
> > > I have a recent version of GRASS on Linux (RedHat 6.1). The system is
> > > 300 MHz with 200 MB RAM. Everything works fine on this system.
> > > I then moved the GRASS build to a faster machine (PIII with 500 MB RAM)
> > > also running RedHat Linux. Again, everything worked fine with the
> > > exception of the monitor. The monitor (sockets) would start but complain
> > > that the socket was unavailable or in use by another program.
> > > I discovered the source of the problem was that d.mon was trying to
> > > select the monitor before it had completely started. I was able to work
> > > around the problem by executing "d.mon -s start=x0" followed by "d.mon
> > > select=x0".
> > > Any thoughts on why this might be happening?
> >Nail on head. Faster machine, executes more code during time slice,
> >oops socket or server is not ready to accept connections. Anyway, 'bout
> >the only thing I can think of is to have d.mon sleep() for a little
> >while before trying to connect or after the first attempt failing. It
> >may be a little trial an error to decide how many seconds and/or if the
> >iterations of "try" should be increased. One second after first failure
> >might be sufficient. I only know that the CELL/PNG drivers are much
> >slower to start up than the X driver.
> >If I wanted to get tricky, I would try to find out if the monitor is
> >running from the process list and try harder to connect if it is, or
> >just quit right away if it isn't. But I think the sleep() hack should
> >be sufficient.
> >grass/src/display/d.mon/cmd/main.c
> >128 if (select->answer)
> >129 {
> >130 oops = run("select", select->answer); /* couldn't select */
> >131 if (oops && start->answer && strcmp (start->answer,
> > select->answer) == 0) /* try once more */
> >132 {
> >133 fprintf (stderr, "Problem selecting %s. Will try
> > once more\n", select->answer);
> >+++ sleep(1);
> >134 oops = run("select", select->answer); /* couldn't
> > select */
> >135 }
> >P.S. Sorry, been a bit distracted from GRASS lately...
> >Eric G. Miller <egm2 at jps.net>
> >If you want to unsubscribe from GRASS Development Team mailing list write
> >to:
> >minordomo at geog.uni-hannover.de with
> >subject 'unsubscribe grass5'
> _________________________________________________________________________
> Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
> If you want to unsubscribe from GRASS Development Team mailing list write to:
