[GRASS5] i.composite
Eric G. Miller egm2 at jps.net
Tue Apr 17 21:46:40 EDT 2001
On Tue, Apr 17, 2001 at 01:57:23PM -0400, mberglund wrote:
> Ok guys, I'm back,
> I am using grass to do some pretty massive image processing(tiling about
> 10gigs of data) and I _think_ I have found a problem with i.composite.
[snip]
> Which seems fine except that after the above file, and its support files
> are done (that is not growing on the harddisk) I am left with a
> processes that is consumeing
>                                              CPU   MEM  TIME
> 11281 matt      18   0  9444 9444   840 R    93.6  2.9  74:59 i.composite
> please note how long it has been running ---------------^
> Is it doing something that I should know about? I have let one run and it
> has gone all night and not exited.
> d.rgb seem to produce the same output in 3-4 minutes on this
> machine.
I can confirm your experience, though I don't have a solution.  Me
thinks a bug in i.composite gets it stuck in an unending loop.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
