[GRASS5] GRASS Monitor
ja id
musliza254 at hotmail.com
Tue Apr 17 21:45:43 EDT 2001
hello ,
i had been download grass5 in linux platform but it can't running completely
.it wanna location,mapset and database...what would i do..and how i'm going
to do...
>From: "Eric G. Miller" <egm2 at jps.net>
>Reply-To: grass5 at geog.uni-hannover.de
>Subject: Re: [GRASS5] GRASS Monitor
>Date: Tue, 17 Apr 2001 18:27:53 -0700
>On Tue, Apr 17, 2001 at 02:43:22PM -0300, Bob Covill wrote:
> > Hello,
> > This is probably a question for Eric.
> > I have a recent version of GRASS on Linux (RedHat 6.1). The system is
> > 300 MHz with 200 MB RAM. Everything works fine on this system.
> > I then moved the GRASS build to a faster machine (PIII with 500 MB RAM)
> > also running RedHat Linux. Again, everything worked fine with the
> > exception of the monitor. The monitor (sockets) would start but complain
> > that the socket was unavailable or in use by another program.
> > I discovered the source of the problem was that d.mon was trying to
> > select the monitor before it had completely started. I was able to work
> > around the problem by executing "d.mon -s start=x0" followed by "d.mon
> > select=x0".
> > Any thoughts on why this might be happening?
>Nail on head. Faster machine, executes more code during time slice,
>oops socket or server is not ready to accept connections. Anyway, 'bout
>the only thing I can think of is to have d.mon sleep() for a little
>while before trying to connect or after the first attempt failing. It
>may be a little trial an error to decide how many seconds and/or if the
>iterations of "try" should be increased. One second after first failure
>might be sufficient. I only know that the CELL/PNG drivers are much
>slower to start up than the X driver.
>If I wanted to get tricky, I would try to find out if the monitor is
>running from the process list and try harder to connect if it is, or
>just quit right away if it isn't. But I think the sleep() hack should
>be sufficient.
>grass/src/display/d.mon/cmd/main.c
>128 if (select->answer)
>129 {
>130 oops = run("select", select->answer); /* couldn't select */
>131 if (oops && start->answer && strcmp (start->answer,
> select->answer) == 0) /* try once more */
>132 {
>133 fprintf (stderr, "Problem selecting %s. Will try
> once more\n", select->answer);
>+++ sleep(1);
>134 oops = run("select", select->answer); /* couldn't
> select */
>135 }
>P.S. Sorry, been a bit distracted from GRASS lately...
>Eric G. Miller <egm2 at jps.net>
>If you want to unsubscribe from GRASS Development Team mailing list write
>to:
>minordomo at geog.uni-hannover.de with
>subject 'unsubscribe grass5'
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
If you want to unsubscribe from GRASS Development Team mailing list write to:
