[GRASS5] GRASS Monitor
Eric G. Miller egm2 at jps.net
Tue Apr 17 21:27:53 EDT 2001
On Tue, Apr 17, 2001 at 02:43:22PM -0300, Bob Covill wrote:
> Hello,
> This is probably a question for Eric.
> I have a recent version of GRASS on Linux (RedHat 6.1). The system is
> 300 MHz with 200 MB RAM. Everything works fine on this system.
> I then moved the GRASS build to a faster machine (PIII with 500 MB RAM)
> also running RedHat Linux. Again, everything worked fine with the
> exception of the monitor. The monitor (sockets) would start but complain
> that the socket was unavailable or in use by another program.
> I discovered the source of the problem was that d.mon was trying to
> select the monitor before it had completely started. I was able to work
> around the problem by executing "d.mon -s start=x0" followed by "d.mon
> select=x0".
> Any thoughts on why this might be happening?
Nail on head.  Faster machine, executes more code during time slice,
oops socket or server is not ready to accept connections.  Anyway, 'bout
the only thing I can think of is to have d.mon sleep() for a little
while before trying to connect or after the first attempt failing.  It
may be a little trial an error to decide how many seconds and/or if the
iterations of "try" should be increased.  One second after first failure
might be sufficient.  I only know that the CELL/PNG drivers are much
slower to start up than the X driver.
If I wanted to get tricky, I would try to find out if the monitor is
running from the process list and try harder to connect if it is, or
just quit right away if it isn't.  But I think the sleep() hack should
be sufficient.
grass/src/display/d.mon/cmd/main.c
128     if (select->answer)
129     {
130         oops = run("select", select->answer); /* couldn't select */
131         if (oops && start->answer && strcmp (start->answer,
		select->answer) == 0) /* try once more */
132         {
133             fprintf (stderr, "Problem selecting %s. Will try
			once more\n", select->answer);
+++             sleep(1);
134             oops = run("select", select->answer); /* couldn't
                        select */
135         }
P.S. Sorry, been a bit distracted from GRASS lately...
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
