[GRASS5] i.composite problems verified
mberglund
mberglund at rcinfo.net
Tue Apr 17 16:38:51 EDT 2001
I have verified that there is a problem on Linux with i.composite.
I can run i.composite on an image group, and it will run forever, LONG
after the output has been generated.
Every thing _seems_ to be ok after you force the software to exit.
Problems: i.composite will not exit after completeing output.
: continues to consume processesor time after output has been
completed.
Any ideas on why this might be?
I have looked at the generated output in every way I can think of, and
have seen no errors. It does not seem to be incomplete in anyway.
Thanks,
Matt
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
