[GRASS5] v.in.arc: import files
Markus Neteler neteler at geog.uni-hannover.de
Tue Apr 17 13:39:52 EDT 2001
On Tue, Apr 17, 2001 at 04:56:22PM +0000, Michel Wurtz wrote:
> Rich Shepard wrote:
> >   Well-l-l, ... m.in.e00, v.in.mif, and v.in.shape all require the
> > fully-qualified path name to work. Just the current directory won't do.
> Uh? I used recently v.in.shape and m.in.e00, and they worked with the
> standard sheme of unix filename, relative path if the name doesn't
> begin with a slash, absolute path if the name begins with a slash...
> BTW, I will take a look tonight at v.in.arc and v.[in|out].dxf to see
> what is the amount of change needed. If possible, I will commit the
> changes.  Markus, should I use a tag my CVS tree to change all in the
> right place (5.0.0, 5.1, ???)
Thanks Michel,
 I suggest only to change the release_branch. Later we will merge back
 into the exp tree (hopefully soon). The 5.1 is quite different, so it
 may not be affected these days.
Regards
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
