[GRASS5] v.in.arc: import files
Michel Wurtz
mw at teledetection.fr
Tue Apr 17 12:56:22 EDT 2001
Rich Shepard wrote:
> Well-l-l, ... m.in.e00, v.in.mif, and v.in.shape all require the
> fully-qualified path name to work. Just the current directory won't do.
Uh? I used recently v.in.shape and m.in.e00, and they worked with the
standard sheme of unix filename, relative path if the name doesn't
begin with a slash, absolute path if the name begins with a slash...
BTW, I will take a look tonight at v.in.arc and v.[in|out].dxf to see
what is the amount of change needed. If possible, I will commit the
changes. Markus, should I use a tag my CVS tree to change all in the
right place (5.0.0, 5.1, ???)
Michel WURTZ - DIG - Maison de la télédétection
500, rue J.F. Breton
34093 MONTPELLIER Cedex 5
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
