[GRASS5] v.in.arc: import files
Rich Shepard rshepard at appl-ecosys.com
Tue Apr 17 12:07:57 EDT 2001
On Tue, 17 Apr 2001, Markus Neteler wrote:
> Is it possible to modify it that v.in.arc reads the file from the
> current directory instead of $LOCATION/arc/ ?
Markus,
  Seems to me that a number of file location issues have surfaced recently
because there is little consistency, apparently, among modules. I would like
to suggest a change to be incorporated into 5.1.
  The default location for all foreign-format source files (perhaps, for all
files) will be the current working directory. This needs to be thought
through and made consistent for the entire system. Also, such a change needs
to be presented early in the documentation so new users understand the
default behavior.
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
 + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
