[GRASS5] java jni bridge for grass
Andreas Lange Andreas.Lange at Rhein-Main.de
Tue Apr 17 06:41:52 EDT 2001
John,
as far as i remember the grass.java libraries are currently _not_
adopted to the grass5 floating point libraries, so they are essentially
useless in the current form.
This is IMHO the reason that they are not installed.
But if someone wants to work on the floating point/grass5 interface it
would be great to know how you built them.
cu,
Andreas
John Huddleston wrote:
> Grass5 list,
> I built the src.garden/grass.java jni system for Cygwin.  There
> was no install target in the gnumakefile.  I have the jar
> file, docs, and the DLLs.
> Where should they be installed?  Anyone interested?
> John Huddleston, P.E.
> USDA Computer Engineer
> (970) 490-8352 (Gpsr)
> huddleston at gpsr.colostate.edu
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
