[GRASS5] Cygwin build for 110401
Andreas Lange Andreas.Lange at Rhein-Main.de
Fri Apr 13 06:31:07 EDT 2001
Hi Markus, John, Malcolm,
i think that we should go first with the installable tar.gz tarball that
Malcolm uploaded.
If we upload an untested zip file without instructions to install we
will get masses of emails asking for help. I can not provide individual
installation support.
If the nviz wish is not installed properly, we should modify the
makefile.
I still insist to make the whole procedure as general as possible. I
believe we should not rely on manual tweaking or on individual
configurations.
And i don't like the idea of distributing binary files that can not be
automatically rebuild.
John, could you please post what you did to compile nviz2.2? Is this
going through the X11 libraries or with the Windows GUI library?
Does the StarNet X Server support OpenGL? I don't think so.
Building PostgresSQL support seems to need the PostgreSQL source
package, my compile dies with message "missing postgres.h". The Postgres
package changed several times the last week. We should wait until this
settles down and we have the opportunity to test the setup.
I did much testing yesterday and will prepare a short report. v.digit
has a very unusual behaviour (you have to press RETURN after each
message), but seems to work generally.
cu,
Andreas
Markus Neteler wrote:
> John,
> Andreas, Malcolm,
> On Thu, Apr 12, 2001 at 05:12:38AM -0600, John Huddleston wrote:
> > Markus,
> > cd incoming
> > unzip nviz-20010411
> > zip grass5-20010411.zip usr/local/grasss5/etc/nviz2.2/
> > zip grass5-20010411.zip usr/local/grasss5/etc/nviz2.2/*
> > zip grass5-20010411.zip usr/local/grasss5/etc/nviz2.2/*/*
> > rm nviz-20010411.zip
> > If you do not have zip and unzip available to you then
> > please remove both zip files and I will upload the binary
> > again.
> > John Huddleston
> o.k, I have added it successfully. However, two questions are still
> there:
>  - for whom is this new package intended
>  - why .zip if we have .tar.gz/grass5install.sh
> Especially considering:
> > > > Of course, under cygwin nvwish does not exist.  So, is the final
> > > > executable supposed to be NVWISH2.2?   Whatever, in the
> > > > nviz-20010411.zip container, it is there three times.
> > > > Let me know what configuration you want.
> Obviously this zip is not intended to the general user?
> Sorry to insist,
>  Markus
> PS: I have to take little care that the Server volume keep in it's
>     size limits.
> > ----- Original Message -----
> > From: "Markus Neteler" <neteler at geog.uni-hannover.de>
> > To: <grass5 at geog.uni-hannover.de>
> > Sent: Thursday, April 12, 2001 3:15 AM
> > Subject: Re: [GRASS5] Cygwin build for 110401
> > > John,
> > > On Wed, Apr 11, 2001 at 02:12:11PM -0600, John Huddleston wrote:
> > > > Markus, (Grass list)
> > > > In the incoming directory is a grass-20010411.zip file and
> > > > a nviz-20010411.zip file.  The install part of nviz did not
> > > > work first time and I did not notice it until after I had uploaded
> > > > the grass5 binary.   Please move them to the http site.
> > > > That section needs some work.  The executable is made in
> > > > the src directory and a Gmakefile later does the move
> > > > 'mv src/nvwish /dev/cvs/grass/dist.i686-pc-cygwin/etc/nviz2.2/NVWISH2.2'
> > > excuse me, but the intention of the packages is not clear to
> > > me. I assume that they are not intended for a wide audience but
> > > to winGRASS developers only? So I would store them in a web
> > > space not read by the mirrors? If we publish GRASS/Cygnus twice
> > > it will be confusing (why both .tar.gz and .zip)...
> > > Please let me know,
> > >  Markus
> > If you want to unsubscribe from GRASS Development Team mailing list write to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass5'
> Markus Neteler *  University of Hannover
> Institute of Physical Geography and Landscape Ecology
> Schneiderberg 50 * D-30167 Hannover * Germany
> Tel: ++49-(0)511-762-4494  Fax: -3984
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
