[GRASS5] Linux binary builder wanted!
Markus Neteler neteler at geog.uni-hannover.de
Thu Apr 12 19:45:09 EDT 2001
Hi Matt,
On Thu, Apr 12, 2001 at 01:59:24PM -0400, mberglund wrote:
> > > It's not that difficult. He/she needs a common machine
> > > fulfilling the REQUIREMENTS to compile GRASS.
> I would certainly be willing (hell, I might even try to
> build some rpms). But I am still having problems with nviz
> (seg faults) on an almost clean suse install (7.1).
> Every thing else seems to work (for some value of work).
thanks for your offer! So let's start (perhaps we communicate
personally later).
Do you have the new release_branch downloaded? To switch
your cvs code to the new release branch, simply enter:
 cvs update -r releasebranch_11_april_2001_5_0_0
This will only transfer changes (as usual). Later on, you can
always update with
 cvs up -dP
as in past.
> If you guys need access to the box, that may be a problem,
> as we are only on a lowly DSL connection.
Please make a fresh compile
 rm config.cache
 rm /usr/local/grass5/lib/libstdc*   # we don't need it, see below
 make distclean
 configure
 make
 make install
and tell us, if the NVIZ problem is still there.
Concerning the libstdc: Please compile "gdal" also from GDAL-cvs,
then you don't need the /usr/local/grass5/lib/libstdc++ (which *may*
cause problems).
I would be glad if we could publish your binary package soon to
involve binary testers, too (any volunteers for this?).
Let me know if you need any assistance,
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
