[GRASS5] [GRASSLIST:1724] EGM96 geoid model?
Markus Neteler neteler at geog.uni-hannover.de
Tue Apr 10 04:14:26 EDT 2001
Hi all,
as Dieter Lehmann has some DNS problems, I am forwarding his mail:
Resent-To: GRASSLIST at baylor.edu
Date: Mon, 09 Apr 2001 14:03:36 +0200 (CEST)
Subject: FW: EGM96
Hello,
(this message might come twice, I get a returned mail because of an not
reachable DNS-Server).
I need some advice in the area of projections...
How to create a location with the following attributes:
Projection: UTM
Horizontal Datum: WGS84
Geoid Model: EGM96 (thats the problem)
Vertical Reference Mean Sea Level (MSL)
It seems, that GRASS have no idea about EGM96, is there another Geoid-name
with the simular specifications?
Is the way correct to import the data into an UTM location, create a
Gaus-Krueger location and import the data from the UTM-location with
r.proj?
Thanks,
Dieter
Dieter Lehmann
University of applied Sciences
Schelmenwasen 4-8
D-72622 Nuertingen, Germany
lehmann at fh-nuertingen.de
Phone: +49 (0) 7022 404 Ext. 192 or Ext. 152
Fax: +49 (0) 7022 404 Ext. 166
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
