[GRASS5] Status of 5.0.0 release
Markus Neteler neteler at geog.uni-hannover.de
Tue Apr 10 03:37:31 EDT 2001
Hi Glynn,
(cc to grass5)
thanks for your various fixes!
Concerning the qsort warnings:
On Mon, Apr 09, 2001 at 07:58:22PM +0100, Glynn Clements wrote:
> Do you want the qsort() warnings fixed? AFAICT, all of these arise
> from comparison functions taking pointers to the actual object type,
> but qsort() having a fixed prototype with a fixed 4th parameter.
> Fixing them is basically a choice of either:
> a) changing e.g.:
> 	int compare(foo *a, foo *b)
> 		return CMP(*a, *b);
> to
> 	int compare(void *aa, void *bb)
> 		foo *a = (foo*) aa;
> 		foo *b = (foo*) bb;
> 		return CMP(*a, *b);
> or:
> b) explicitly casting the 4th argument to qsort()
> If you want this fixed, which approach would you prefer?
> OTOH, the "fixed" code is possibly uglier than the code which
> generates warnings, due to the explicit typecasts.
> Glynn Clements <glynn.clements at virgin.net>
this I would like to put into general discussion. Maybe we can silently
ignore the qsort warnings (no problems in past)?
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
