[GRASS5] Status of 5.0.0 release
Markus Neteler neteler at geog.uni-hannover.de
Mon Apr 9 11:47:32 EDT 2001
On Mon, Apr 09, 2001 at 03:50:04PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > > > as it becomes rather siltent in CVS, I suggest to release
> > > > GRASS 5.0.0 *now*.
> > > > We have three RC tagged bugs left in BUGS and a few in
> > > > RT-service. However, I don't see that they get fixed in
> > > > reasonable time.
> > > Is [bug #229] applicable to the release candidate? (I'm using the
> > > bleeding-edge version, so I don't know).
> > > If it is, it should be fixed (I can provide a patch if necessary). If
> > > developers haven't been bitten by this, maybe it's because they have
> > > write permission on their PERMANENT mapset(s). End users are more
> > > likely to be bitten by it.
> > Hi Glynn,
> > thanks for fixing it (I assume it was #229 as RT is still down).
> Yes, it was #229.
> BTW, I have the CVS "head" checked out, not the release branch; I
> don't know if or how this affects the release (I've never managed to
> get to grips with CVS branches; I'm still not quite sure whether I
> really understand how non-branch tags work).
By tomorrow, when the new branch is applied, we all have the pleasure
to learn it... I hope only a few fixes are required to be applied to
the branch.
Regards
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
