[GRASS5] 'unsubscribe grass5'
Tinus Joubert
tinus at netbus.co.za
Wed Apr 4 09:18:17 EDT 2001
----- Original Message -----
To: <grass5 at geog.uni-hannover.de>
Sent: Wednesday, April 04, 2001 10:43 AM
Subject: Re: [GRASS5] Arrow keys and default pager
> > Second issue: I see that the default pager for GRASS man pager is
> > "more",
> > but under linux the default pager is usually "less", much more powerful
> > and easier to use. I'm getting tired of typing "export PAGER=less" every
> > time I login in GRASS... couldn't it be a default option if "less" is
> > available on the machine (at least under Linux)?
> Hallo,
> I had the same thoughts a couple of days before. A possible solution
> would be:
> Replacing the lines
> # Set some environment variables if they are not set
> if [ ! "$PAGER" ] ; then
> PAGER=more
> export PAGER
> fi
> with
> lesspath=`which less 2> /dev/null`
> if [ -x "$lesspath" ] ; then
> PAGER=less
> else
> PAGER=more
> fi
> export PAGER
> fi
> in file grass5/etc/Init.sh (About line 61). Works fine for me.
> R. Brunzema
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
If you want to unsubscribe from GRASS Development Team mailing list write to:
