[GRASS5] 'unsubscribe grass5'
Tinus Joubert
tinus at netbus.co.za
Wed Apr 4 09:18:25 EDT 2001
----- Original Message -----
To: <grass5 at geog.uni-hannover.de>
Sent: Wednesday, April 04, 2001 11:15 AM
Subject: Re: [GRASS5] Arrow keys and default pager
> On Wed, Apr 04, 2001 at 10:43:26AM +0200, Reinhard Brunzema wrote:
> > > Second issue: I see that the default pager for GRASS man pager is
> > > "more",
> > > but under linux the default pager is usually "less", much more
powerful
> > > and easier to use. I'm getting tired of typing "export PAGER=less"
every
> > > time I login in GRASS... couldn't it be a default option if "less" is
> > > available on the machine (at least under Linux)?
> > Hallo,
> > I had the same thoughts a couple of days before. A possible solution
> > would be:
> > Replacing the lines
> > # Set some environment variables if they are not set
> > if [ ! "$PAGER" ] ; then
> > PAGER=more
> > export PAGER
> > fi
> > with
> > lesspath=`which less 2> /dev/null`
> > if [ -x "$lesspath" ] ; then
> > PAGER=less
> > else
> > PAGER=more
> > fi
> > export PAGER
> > fi
> The "which" command is not Bourne Shell (unfortunately). I've seen
> hacks to emulate it...
> Eric G. Miller <egm2 at jps.net>
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
If you want to unsubscribe from GRASS Development Team mailing list write to:
