[GRASS5] Arrow keys and default pager
Reinhard Brunzema
r.brunzema at web.de
Wed Apr 4 04:43:26 EDT 2001
> Second issue: I see that the default pager for GRASS man pager is
> "more",
> but under linux the default pager is usually "less", much more powerful
> and easier to use. I'm getting tired of typing "export PAGER=less" every
> time I login in GRASS... couldn't it be a default option if "less" is
> available on the machine (at least under Linux)?
Hallo,
I had the same thoughts a couple of days before. A possible solution
would be:
Replacing the lines
# Set some environment variables if they are not set
if [ ! "$PAGER" ] ; then
PAGER=more
export PAGER
fi
with
lesspath=`which less 2> /dev/null`
if [ -x "$lesspath" ] ; then
PAGER=less
else
PAGER=more
fi
export PAGER
fi
in file grass5/etc/Init.sh (About line 61). Works fine for me.
R. Brunzema
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
