[GRASS5] Problems compiling r.fill.dir
Roger S. Miller rgrmill at Rt66.com
Tue Apr 3 22:40:20 EDT 2001
Malcolm Blue wrote:
> Fortran programmers,
> It's been a long time since I've done any fortran programming.  The
> compile for r.fill.dir exits with the following error messages:
Malcom,
These look like some ugly problems.  I think the version of r.fill.dir
now in the CVS tree is the one that I hacked to use floating point
elevations.  It compiled without problems on i586-pc-linux and ran fine
for me, but not well for Markus.  Markus since asked Huidae Cho to look
into the problems, because I pretty much ran out of time.
The cygwin port of g77 must be more exacting than my linux port when it
comes to COMMON blocks.  The problem appears to be with the LEVEL
array.  In the original source code I think it was declared as REAL *2
LEVEL(4002,3).  I changed that to DOUBLE PRECISION LEVEL(4002,3) in all
of the subroutine where LEVEL was used, but apparently didn't change it
in those subroutine where it wasn't referenced.  One of the blank COMMON
statements excludes LEVEL entirely, which may be a feature of the
original code.
> There are a number of messages of the same type.  Is it possible to
> reorder the variables on the common blocks defined in r.fill.dir, or is
> there a switch to g77 that will tell it to align members of a common
> block to the same byte length?
I don't know if g77 has a switch that relaxes it's restrictions on blank
COMMON.  Unfortunately my server at work seems to be off line and I
can't reach my sources or the documentation.  I got the ppupdate.f
source in the CVS tree and it looks like it may be sufficient to just
make a few changes.
LEVEL is declared as INTEGER *2 in subroutines PATH, FIXALOOP, UPDATE,
and DOMAPTO.  In each case the source may need to declare LEVEL as
DOUBLE PRECISION.  Additionally, subroutine FILL doesn't declare LEVEL
at all and it may be necessary to add it's declaration (as DOUBLE
PRECISION) to that subroutine.
If your g77 insists on having the large variable declared first, then
you can probably change their order.  The change needs to be made in all
of the "COMMON MASK,LEVEL" statements.  Change them to "COMMON
LEVEL,MASK".  In addition, the DO3BY3 subroutine declares the block as
"COMMON MASK,ELEV" and this needs to be changed to "COMMON ELEV,MASK".
In fact, it might be necessary to rename ELEV to LEVEL in that
subroutine.
> Any other suggestions?
If you don't need r.fill.dir right away, then hold off on trying to fix
it.  I'm converting the source to C and that should be ready in a few
weeks, depending on how much time I have available to work on it.
Huidae Cho may also be working on the source.  If you do need it right
away then I can probably send you a copy with the changes I described
above.
Roger Miller
Lee Wilson and Associates
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
