[GRASS5] Problems compiling r.fill.dir
Malcolm Blue
mblue at nb.sympatico.ca
Tue Apr 3 19:05:53 EDT 2001
Fortran programmers,
It's been a long time since I've done any fortran programming. The
compile for r.fill.dir exits with the following error messages:
g77 -c ppupdate.f -o OBJ.i686-pc-cygwin/ppupdate.o
ppupdate.f: In program `MAIN__':
ppupdate.f:14: warning:
COMMON MASK,LEVEL
Initial padding for common block `_BLNK__' is 4 bytes at (^) -- consider
reordering members, largest-type-size first
ppupdate.f: In subroutine `path':
ppupdate.f:14:
COMMON MASK,LEVEL
1
ppupdate.f:267: (continued):
COMMON MASK,LEVEL
2
Initial padding for common block `_BLNK__' is 0 bytes at (2) but 4 bytes
at (1) -- consider reordering members, largest-type-size first
ppupdate.f: In subroutine `fixaloop':
<snip> They go on for a while.
ppupdate.f:478: (continued):
COMMON MASK
2
make[3]: *** [OBJ.i686-pc-cygwin/ppupdate.o] Error 1
make[3]: Leaving directory `/grass/src/raster/r.fill.dir/cmd'
make[2]: *** [all] Error 1
There are a number of messages of the same type. Is it possible to
reorder the variables on the common blocks defined in r.fill.dir, or is
there a switch to g77 that will tell it to align members of a common
block to the same byte length?
Any other suggestions?
Thanks,
Malcolm
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
