[GRASS5] Re: .grassrc preferences file
Markus Neteler neteler at itc.it
Mon Aug 6 04:42:00 EDT 2001
Hi Rich,
I have added a hint concerning the env.vars on
http://www.geog.uni-hannover.de/grass/gdp/html_grass5/index.html
-> GRASS startup
(I expect a user would check that page)
Tell me if you want it to be improved. Please note that the
env_var.html page is not yet well maintained... More input to
 html/env_vars.html
is very welcome.
Cheers
Markus
On Fri, Aug 03, 2001 at 10:21:10AM -0700, Rich Shepard wrote:
>   I cannot find reference to a preferences file. When I read the d.mon man
> page I see that I can change the color depth, but that must be done manually
> each time (monitorcap doesn't support this variable). Also, if I want the
> default monitor window size to be larger, I have to explictly export those
> variable each time, or put them in ~/.bashrc.
>   How much trouble would it be to add a .grassrc capability to 5? User
> preferences, such as monitor window size, color depth, etc. -- and I don't
> even know what else it could accommodate -- could be defined there on a
> user-by-user basis. That would also provide a single place for GRASS to look
> for these variables.
> Thoughts?
> Rich
> Dr. Richard B. Shepard, President
>                        Applied Ecosystem Services, Inc. (TM)
>             2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
>  + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
>                  Making environmentally-responsible mining happen.
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18
38050 Trento (Povo), Italia
tel +39 0461 314 520                         neteler at itc.it
fax +39 0461 314 591                      http://mpa.itc.it
