[GRASS5] Re: r.drain, postgresql
Markus Neteler
neteler at itc.it
Mon Aug 6 10:09:44 EDT 2001
Hi Andreas,
On Mon, Aug 06, 2001 at 04:06:17PM +0200, Andreas Lange wrote:
> Hi Roger, Hi Markus,
> i am going to check in two small changes to the new r.drain code. It
> does not compile on cygwin due to the values.h header missing on cygwin.
> We discussed all this back in 11/2000, so i hope the change i checked in
> works on all systems now. BUt i did not test if the fix affects the code
> directly, so Roger please check this.
it seems you are not using the latest r.drain from CVS. I had fixed
the problem:
value.h -> #include <limits.h>
That's the portable code.
> Markus, i'll check in two small fixes for the postgreSQl code, i can now
> compile on cygwin.
> Please contact me if there are any problems.
> cu,
> Andreas
Fine, thanks for the upcoming fixes,
Markus
