[GRASS5] Re: r.drain, postgresql
Roger S. Miller rgrmill at rt66.com
Mon Aug 6 22:07:27 EDT 2001
Andreas, and all,
I'm still here!  Well, as much as usual anyway.  I think the address in
the readme is good, but letters may have bounced a couple days ago when
my ISP was down for an equipment change -- they changed their building.
Markus has been handling all my contributions.  I don't have a locally
archived copy of r.drain, and I have never set up CVS access or learned
how to use CVS.  That makes it relatively difficult for me to fix
problems in my own code.
Markus, I guess you can take that as an official request for CVS access.
Roger
Andreas Lange wrote:
> Hi Markus,
> there was another problem with the code:
> MAXDOUBLE and HUGE are IMHO not in limits.h, but in values.h, one has to
> use:
> DBL_MAX and HUGE_VAL.
> This was shaded from the compiling because values.h was included in
> tinf.h a second time, so that the old includes from values.h have been
> used. At this point the compiling failed on cygwin.
> Could you forward this message to Roger S. Miller, the mail addres from
> the readme file in the code bounced back to me.
> HTH,
> Markus Neteler wrote:
> > Hi Andreas,
> > On Mon, Aug 06, 2001 at 04:06:17PM +0200, Andreas Lange wrote:
> > > Hi Roger, Hi Markus,
> > > i am going to check in two small changes to the new r.drain code. It
> > > does not compile on cygwin due to the values.h header missing on cygwin.
> > > We discussed all this back in 11/2000, so i hope the change i checked in
> > > works on all systems now. BUt i did not test if the fix affects the code
> > > directly, so Roger please check this.
> > it seems you are not using the latest r.drain from CVS. I had fixed
> > the problem:
> > value.h -> #include <limits.h>
> > That's the portable code.
> > > Markus, i'll check in two small fixes for the postgreSQl code, i can now
> > > compile on cygwin.
> > > Please contact me if there are any problems.
> > > cu,
> > > Andreas
> > Fine, thanks for the upcoming fixes,
> >  Markus
> Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
> url: http://mitglied.tripod.de/AndreasLange
> mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
> grass5 mailing list
> grass5 at geog.uni-hannover.de
> http://www.geog.uni-hannover.de/mailman/listinfo/grass5
