[GRASS5] Re: [winGRASS] ARG_MAX and parser.c
Glynn Clements
glynn.clements at virgin.net
Wed Aug 8 13:59:28 EDT 2001
Markus Neteler wrote:
> may someone clarify below?
> On Tue, Aug 07, 2001 at 04:07:06AM -0600, John Huddleston wrote:
> > Wingrass,
> > I see that someone checked in src/libes/gis/parser.c with ARG_MAX
> > It used to be 1024 in size. The Posix size is 4096. Normally this is
> > in the limits.h file. Maybe we can put something in out gis.h header.
> > The char *G_recreate_command (void) function uses it lines 1365
> > and 1369.
> > #ifndef ARG_MAX
> > #define ARG_MAX 4096
> > #endif
> > Is that too large a size?
I have no idea which version of src/libes/gis/parser.c this refers to.
It isn't the version in releasebranch_11_april_2001_5_0_0. That
version doesn't reference ARG_MAX; instead, it uses G_realloc to
enlarge the buffer as required.
Glynn Clements <glynn.clements at virgin.net>
