[GRASS5] r.in.gdal linking
Wed Aug 8 17:52:45 EDT 2001
Folks,
I have introduced the option of linking r.in.gdal directly against GDAL
instead
of using the run time loading mechanism.  This is primarily intended to
allow
building r.in.gdal on platforms without shared libraries and dlopen().
I just checked into the default CVS branch, I am not quite sure where things
are supposed to go now.  Let me know if anyone encounters problems or
whats to test out the new build option.
Best regards,
