[GRASS5] Inconsistencies among modules
Frank Warmerdam
warmerdam at pobox.com
Wed Aug 8 20:35:58 EDT 2001
Helena wrote:
>Frank Warmerdam wrote:
>>Rich Shepard wrote:
>>> Two inconsistencies I've picked up:
>>> 1) Some modules (e.g., r.in.gdal, r.patch) allow the use of an existing
>>>output file name with no warning that that file already exists, and asking
>>>the user if it's OK to overwrite it. Other modules (e.g., r.poly, v.digit)
>>>tell the user that the output file name exists, does not ask for directions,
>>>and refuses to let the user overwrite it. Recommendation: always check,
>>>always ask, follow the user's directions.
>>Folks,
>>What would the normal mechanism be to ask the user if they want to overwrite
>>an existing raster layer?
>r.mapcalc does it the right way, most of other programs don't
>mapcalc> diff=owhusle-owhusle.rst
>diff - already exists. ok to overwrite? (y/n)
Folks,
For reference, r.mapcalc only prompts if it is in interactive mode, which it
determines using "interactive = isatty(0)". It uses
"G_find_file ("cell",result,G_mapset())" to test if the raster already
exists,
and G_yes() to test for a user response.
I presume it just overwrites silently if not in interactive mode.
As someone (email already deleted!) pointed out, G_parser() actually
does this
sort of existance test if it prompts for the raster name, but not if
supplied on
the command line. Should we look at fixing G_parser() to check for command
line arguments too instead of trying to build alot of logic into each
program?
If so, should we leave this for post 5.0? I hate to make dramatic system
wide
changes shortly before a release.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
