[GRASS5] Inconsistencies among modules
Helena hmitaso at unity.ncsu.edu
Wed Aug 8 22:06:39 EDT 2001
Frank Warmerdam wrote:
> >>Rich Shepard wrote:
> >>> Two inconsistencies I've picked up:
> >>> 1)  Some modules (e.g., r.in.gdal, r.patch) allow the use of an existing
> >>>output file name with no warning that that file already exists, and asking
> >>>the user if it's OK to overwrite it. Other modules (e.g., r.poly, v.digit)
> >>>tell the user that the output file name exists, does not ask for directions,
> >>>and refuses to let the user overwrite it. Recommendation: always check,
> >>>always ask, follow the user's directions.
> >>Folks,
> >>What would the normal mechanism be to ask the user if they want to overwrite
> >>an existing raster layer?
> >r.mapcalc does it the right way, most of other programs don't
> >mapcalc> diff=owhusle-owhusle.rst
> >diff - already exists. ok to overwrite? (y/n)
> Folks,
> For reference, r.mapcalc only prompts if it is in interactive mode, which it
> determines using "interactive = isatty(0)".  It uses
> "G_find_file ("cell",result,G_mapset())" to test if the raster already
> exists,
> and G_yes() to test for a user response.
> I presume it just overwrites silently if not in interactive mode.
> As someone (email already deleted!) pointed out, G_parser() actually
> does this
> sort of existance test if it prompts for the raster name, but not if
> supplied on
> the command line.  Should we look at fixing G_parser() to check for command
> line arguments too instead of trying to build alot of logic into each
> program?
> If so, should we leave this for post 5.0? I hate to make dramatic system
> wide
> changes shortly before a release.
definitely for post 5.0 This is not the kind of change that should be done now.
Helena
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
