[GRASS5] Environment variable listings...
Eric G. Miller
egm2 at jps.net
Fri Aug 10 01:23:13 EDT 2001
Do you think people would find it useful if g.gisenv could list all of
the known environment variables with a bit of information about them?
I've hacked my copy of g.gisenv to do this via an "-l" flag. Output is
like:
----------------------<snippet>----------------------------------
VARIABLE :: GRASS_FP_DOUBLE [(nil)]
DESCRIPTION :: Default type of floating point representation for floating point rasters.
DOMAIN :: DCELL_TYPE | FCELL_TYPE
EXAMPLE :: GRASS_FP_DOUBLE=FCELL_TYPE
Press Enter to continue ('q' to quit)>
VARIABLE :: GRASS_HEIGHT [2400]
DESCRIPTION :: Define height of CELL driver output
DOMAIN :: Positive integer
EXAMPLE :: GRASS_HEIGHT=480
It pauses between entries iff isatty(1) is true. It does not interfere
with the get/set behavior currently in place.
Seems it's never easy enough to figure out what environment variables
are available for controlling behaviors... Developer's can easily add
to the struct array if there's a module that recognizes a certain
variable and it's not yet "registered".
Opinions?
Eric G. Miller <egm2 at jps.net>
