[GRASS5] ODBC driver build problem
    Markus Neteler
    neteler at itc.it
    Thu Aug 23 12:42:54 EDT 2001
On Fri, Aug 10, 2001 at 09:05:20AM -0400, Frank Warmerdam wrote:
> A few other "developer" questions:
>  o How do folks normally do quick global builds when they just want to
>     refresh things.  I find the current mechanisms insistance on
>     reprocessing
>    all the html/man stuff makes it very slow to do a top level make.
Frank,
I am not sure if you received an answer here:
It's pretty easy:
Compiling a local module (after once having run all the
 configure;make;make install
procedure) can be done with
gmake5 -i
gmakelinks5 -i  # this one only required if module not yet present in GRASS
Enjoy,
 Markus
