[GRASS5] WARNING: CVS broken
Jan-Oliver Wagner
jan at intevation.de
Fri Aug 10 02:43:26 EDT 2001
On Thu, Aug 09, 2001 at 11:31:54PM +0100, Glynn Clements wrote:
> > > repository has suffered a botched merge attempt. I *really* hope that
> > > someone has a backup.
> > If there are no better solutions then I have the the entire tagged release
> > that I downloaded and updated about 4 1/2 hours ago. I've made no changes.
> I meant a backup of the repository itself; I reverted my local copy
> with "cvs update -r ... -D ...".
> But the repository itself would ideally be restored to the state it
> was in before the snafu. Otherwise there's going to be a pretty
> massive artifact in the revision history. Unfortunately CVS doesn't
> have a "rollback" command.
before we'll have a look at the trouble, just a comment:
The CVS repository is mirrored each night to another
computer (in some kilometers distance from the main server,
so that even a fire or something like that can not destroy
original and backups at the same time).
Furthermore every evening the whole stuff is written to a tape.
Since we don't reuse tapes, there is a large quantity now
that ranges back to the beginning of the GRASS CVS
allowing to retrieve a repository for almost any date.
Hope you can sleep better now :-)
Jan
Jan-Oliver Wagner http://intevation.de/~jan/
Intevation GmbH http://intevation.de/
FreeGIS http://freegis.org/
