[GRASS5] Time to go mad: CVS completely messed up?!
Bernhard Reiter
bernhard at intevation.de
Tue Aug 14 13:24:56 EDT 2001
On Tue, Aug 14, 2001 at 06:11:31PM +0100, Glynn Clements wrote:
> Bear in mind that any information regarding the
> releasebranch_11_april_2001_5_0_0 tag may be completely bogus. If my
> suspicion is correct, the repository has been tagged twice with this
> tag.
I am still in the process of inquiring.
Please _hold_ to commit changes to the CVS,
until we can find out what has happened.
Glynn: It looks like your suspicion might be correct.
According to the following output,
a command which everybody can use to find out about the
Tags and Branches of a file without checking out the file,
"releasebranch_11_april_2001_5_0_0" is not a branch.
$ cvs -z2 status -v main.c
File: main.c Status: Up-to-date
Working revision: 1.3
Repository revision: 1.3
/grassrepository/grass/src/display/d.rgb/cmd/main.c,v
Sticky Tag: (none)
Sticky Date: (none)
Sticky Options: (none)
Existing Tags:
releasebranch_14_august_2001_5_0_0 (branch: 1.3.4)
releasebranch_11_april_2001_5_0_0 (revision: 1.3)
devices_cleanup_20000420 (revision: 1.3)
grassreleasebranch_5_0_0 (branch: 1.3.2)
releasebranch_5_0_0 (revision: 1.3)
releasebranch_500 (revision: 1.3)
testbranch_5_0_0stable (revision: 1.2)
release_grass5beta11_4_february_2001 (revision: 1.2)
release_grass5beta11pre2_28_january_2001 (revision: 1.2)
release_grass5beta11pre1_21_january_2001 (revision: 1.2)
release_grass5beta10_7_december_2000 (revision: 1.1.1.1)
release_grass5beta9_6_december_2000 (revision: 1.1.1.1)
release_grass5beta8_26_july_2000 (revision: 1.1.1.1)
release_grass5beta7_20_april_2000 (revision: 1.1.1.1)
release_grass5beta6_16_feb_2000 (revision: 1.1.1.1)
start (revision: 1.1.1.1)
grass (branch: 1.1.1)
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Association for a Free Informational Infrastructure (ffii.org)
FSF Europe (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010814/ed8a9ac7/attachment.bin
