CVS analysis (Re: [GRASS5] Time to go mad: CVS completely messed up?!)
Bernhard Reiter
bernhard at intevation.de
Tue Aug 14 15:47:09 EDT 2001
> Now I will dig into the history command options to find out
> what actions caused this behaviour.
The history does not contain enough information to find out
what has happened when.
I found out, though that there might be a way to find all files within
the repository which are on a non-branch "releasebranch_11_april_2001_5_0_0"
tag.
Removing the line with the tag in the repository file might then cure
the problem.
Glynn: I removed the d.rgb/cmd/main.c again after checking out the
releasebranch_11_april_2001_5_0_0 version and it looks like this
just removed the Revision tag.
Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Association for a Free Informational Infrastructure (ffii.org)
FSF Europe (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010814/2a5141ff/attachment.bin
