[GRASS5] WARNING: CVS broken
Markus Neteler
neteler at itc.it
Thu Aug 16 12:42:02 EDT 2001
On Thu, Aug 16, 2001 at 06:36:17PM +0200, Bernhard Reiter wrote:
> Files, which have been checkout and commited
> in the time period where there were the irritating non-branch tags
> where in the repository might have landed on the wrong branch.
> On Thu, Aug 16, 2001 at 06:17:41PM +0200, Markus Neteler wrote:
> > while investigatin if all recent fixes have reached the CVS,
> > I found this inconsistency (am I'm wrong?):
> > cat html/html/r.in.gdal.html |tail -3
> > <p><i>Last changed: $Date: 2001/07/09 12:43:32 $</i>
> > Running
> > "make changelog" (rather equal to cvs2cl.pl) I find:
> > 2001-08-08 23:09 frankw
> > * html/html/r.in.gdal.html: added notes on null support
> > Obviously this is not in CVS (and more). Where is it gone?
> It is in the cvs in the main branch:
> Check:
> http://freegis.org/cgi-bin/viewcvs.cgi/grass/html/html/r.in.gdal.html
> and
> http://freegis.org/cgi-bin/viewcvs.cgi/grass/html/html/r.in.gdal.html.diff?r1=text&tr1=1.8.2.2&r2=text&tr2=1.9&diff_format=h
> That is the good part of cvs: It rarely looses data at all
> if it was checked in once.
However, in this case Frank Warmerdam first checked into exp tree, then
(after I realized that) into the release branch.
> > Dear developers, please check if your changes are present
> > in current CVS.
Is there any way to cvs diff the wrong release branch and the active
one to find the mis-checked modules?
Thanks for your patience,
Markus
