[GRASS5] configure/libGL fails on Solaris
Markus Neteler
neteler at itc.it
Thu Aug 23 08:56:31 EDT 2001
if anyone has a hint for me - I tested the current
configure on SUN/solaris 2.6, it fails to detect
the libGL (although present). Some lib is missing for
the text, see attachement. Might be trivial, but
I need a hint what to add,
thanks
Markus
configure:6009: checking for glBegin in -lGL
configure:6028: gcc -o conftest -g -O2 -L/usr/lib conftest.c -lGL -L/usr/openwin/lib -R/usr/openwin/lib -lm 1>&5
Undefined first referenced
symbol in file
XSynchronize /usr/lib/libGL.so
XShmPutImage /usr/lib/libGL.so
XDrawPoint /usr/lib/libGL.so
XFreeColors /usr/lib/libGL.so
XFreePixmap /usr/lib/libGL.so
XQueryColors /usr/lib/libGL.so
XShmQueryVersion /usr/lib/libGL.so
XCreateImage /usr/lib/libGL.so
XGetWindowProperty /usr/lib/libGL.so
XCopyArea /usr/lib/libGL.so
XSetDashes /usr/lib/libGL.so
XFreeFontInfo /usr/lib/libGL.so
XCreatePixmap /usr/lib/libGL.so
XSetLineAttributes /usr/lib/libGL.so
XSync /usr/lib/libGL.so
XUngrabKeyboard /usr/lib/libGL.so
XGetVisualInfo /usr/lib/libGL.so
XFlush /usr/lib/libGL.so
XUngrabPointer /usr/lib/libGL.so
XQueryFont /usr/lib/libGL.so
XSetBackground /usr/lib/libGL.so
XAllocColor /usr/lib/libGL.so
XSetStipple /usr/lib/libGL.so
XShmDetach /usr/lib/libGL.so
XFreeGC /usr/lib/libGL.so
XSetPlaneMask /usr/lib/libGL.so
XSetForeground /usr/lib/libGL.so
XFree /usr/lib/libGL.so
XGetIconName /usr/lib/libGL.so
XFillPolygon /usr/lib/libGL.so
XFillRectangle /usr/lib/libGL.so
XShmCreateImage /usr/lib/libGL.so
XDrawString16 /usr/lib/libGL.so
XQueryExtension /usr/lib/libGL.so
XCreateColormap /usr/lib/libGL.so
XShmAttach /usr/lib/libGL.so
XCreateGC /usr/lib/libGL.so
XSetErrorHandler /usr/lib/libGL.so
XPutImage /usr/lib/libGL.so
XGetWindowAttributes /usr/lib/libGL.so
XGetGeometry /usr/lib/libGL.so
XSetFunction /usr/lib/libGL.so
XSetFillStyle /usr/lib/libGL.so
XGetImage /usr/lib/libGL.so
XSetTile /usr/lib/libGL.so
XInternAtom /usr/lib/libGL.so
ld: fatal: Symbol referencing errors. No output written to conftest
configure: failed program was:
#line 6017 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char glBegin();
int main() {
glBegin()
; return 0; }
configure:6049: checking for glBegin in -lGL
configure:6068: gcc -o conftest -g -O2 -L/usr/lib conftest.c -lGL -L/usr/openwin/lib -R/usr/openwin/lib -lm -lpthread 1>&5
symbol in file
#line 6057 "configure"
char glBegin();
int main() {
glBegin()
; return 0; }
configure:6095: checking for gluBeginCurve in -lGLU
configure:6114: gcc -o conftest -g -O2 -L/usr/lib conftest.c -lGLU -L/usr/openwin/lib -R/usr/openwin/lib -lm 1>&5
symbol in file
glFrontFace /usr/lib/libGLU.so
glGetFloatv /usr/lib/libGLU.so
glTranslated /usr/lib/libGLU.so
glOrtho /usr/lib/libGLU.so
glViewport /usr/lib/libGLU.so
glPixelStorei /usr/lib/libGLU.so
glMap1f /usr/lib/libGLU.so
glGetIntegerv /usr/lib/libGLU.so
glTexCoord2f /usr/lib/libGLU.so
glMatrixMode /usr/lib/libGLU.so
glPushAttrib /usr/lib/libGLU.so
glPopMatrix /usr/lib/libGLU.so
glNormal3f /usr/lib/libGLU.so
glMap2f /usr/lib/libGLU.so
glEvalPoint2 /usr/lib/libGLU.so
glEvalMesh1 /usr/lib/libGLU.so
glEvalMesh2 /usr/lib/libGLU.so
glGetDoublev /usr/lib/libGLU.so
glMapGrid2f /usr/lib/libGLU.so
glLoadMatrixf /usr/lib/libGLU.so
glEvalCoord2f /usr/lib/libGLU.so
glBegin /usr/lib/libGLU.so
glDisable /usr/lib/libGLU.so
glPopAttrib /usr/lib/libGLU.so
glMultMatrixd /usr/lib/libGLU.so
glMultMatrixf /usr/lib/libGLU.so
glEnd /usr/lib/libGLU.so
glPushMatrix /usr/lib/libGLU.so
glMapGrid1f /usr/lib/libGLU.so
glTexImage1D /usr/lib/libGLU.so
glTexImage2D /usr/lib/libGLU.so
glEnable /usr/lib/libGLU.so
glVertex2d /usr/lib/libGLU.so
glVertex2f /usr/lib/libGLU.so
glFrustum /usr/lib/libGLU.so
glVertex3d /usr/lib/libGLU.so
glVertex3f /usr/lib/libGLU.so
#line 6103 "configure"
char gluBeginCurve();
int main() {
gluBeginCurve()
; return 0; }
configure:6165: checking for location of ODBC includes
