[GRASS5] configure/libGL fails on Solaris
Bernhard Reiter bernhard at intevation.de
Thu Aug 23 09:03:49 EDT 2001
On Thu, Aug 23, 2001 at 02:56:31PM +0200, Markus Neteler wrote:
> if anyone has a hint for me - I tested the current
> configure on SUN/solaris 2.6, it fails to detect
> the libGL (although present). Some lib is missing for
> the text, see attachement. Might be trivial, but
> I need a hint what to add,
Somehow the right X11 libs are needed and missing.
(Usually it should be tested before the GL support or you might need
to speficy extra xlibs....)
> configure:6009: checking for glBegin in -lGL
> configure:6028: gcc -o conftest -g -O2   -L/usr/lib conftest.c -lGL  -L/usr/openwin/lib -R/usr/openwin/lib -lm  1>&5
> Undefined			first referenced
>  symbol  			    in file
> XSynchronize                        /usr/lib/libGL.so
> XShmPutImage                        /usr/lib/libGL.so
> XDrawPoint                          /usr/lib/libGL.so
> XFreeColors                         /usr/lib/libGL.so
> XFreePixmap                         /usr/lib/libGL.so
> XQueryColors                        /usr/lib/libGL.so
> XShmQueryVersion                    /usr/lib/libGL.so
> XCreateImage                        /usr/lib/libGL.so
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010823/a53f2ea4/attachment.bin
