[GRASS5] Polygon Simplification... (d.area revisited)
Glynn Clements glynn.clements at virgin.net
Tue Dec 11 10:48:18 EST 2001
Alex Shevlakov wrote:
> I guess this is to enable functions like R_polygon_abs
> to handle islands?
R_polygon_abs wouldn't be the right place for it. However, it would
allow d.area to tesellate the shape into a set of convex polygons,
each of which would be passed to R_polygon_abs.
The input to R_polygon_abs is just a list of points, which implies a
single continuous path. Complex shapes (with islands) comprise
multiple paths, requiring either a list of lists of points, or
distinct moveto/lineto operations (as in PostScript).
Also, doesn't v.report need something like this for area computations?
Glynn Clements <glynn.clements at virgin.net>
