[GRASS5] Polygon Simplification... (d.area revisited)
Alex Shevlakov
sixote at yahoo.com
Tue Dec 11 07:48:54 EST 2001
hi
I guess this is to enable functions like R_polygon_abs
to handle islands?
--alex
--- "Eric G. Miller" <egm2 at jps.net> wrote:
> Okay, haven't finished implementing it yet, but I
> managed to try
> writing up how I'm attempting to do it...
> (bring out the way-back machine about d.area and
> handling
> holes as well as clipping...).
> I think I understand an algorithm that should
> produce the
> desired results. But I haven't yet finished
> implementing it.
> Given, it might take me a while to get it done, I
> thought I'd
> try to explain it, and if any enterprising soul
> wants to
> give it a crack... just try to get it done before I
> do ;-)
> I've posted a little write-up and some poorly done
> graphics
> that try to illustrate the process at:
http://pweb.jps.net/~egm2/grass/algorithms/poly_simplify/algorithm.html
> Perhaps it will make sense to someone? Perhaps it
> is flawed?
> Perhaps I will figure out how to get working code
> for it...?
> With a little bit more thought, I think the general
> concept
> described can be extended/modified for general
> overlay
> operations...
> Eric G. Miller <egm2 at jps.net>
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
__________________________________________________
Do You Yahoo!?
Check out Yahoo! Shopping and Yahoo! Auctions for all of
your unique holiday gifts! Buy at http://shopping.yahoo.com
or bid at http://auctions.yahoo.com
