[GRASS5] [bug #879] (grass) s.reclass: obviously not working
Eric G. Miller
egm2 at jps.net
Tue Dec 18 21:58:15 EST 2001
On Tue, 18 Dec 2001 18:37:17 +0100 (CET), Request Tracker <grass-bugs at intevation.de> wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=879
> Subject: s.reclass: obviously not working
> Hi,,
> any awk guru out there?
> Today I tried s.reclass with no avail. Neither
> 1 2 3 4 = 1
> nor
> 1 thru 4 = 1
> nor
> 1 = 2
> rule is accepted.
> I remember that the script was working once...
> The awk-based script is in
> src/scripts/contrib/s.reclass
> Perhaps worth a fix,
> thanks
> Markus
> PS: I have at least improved the cmd line "parser" today...
It makes some assumptions about sites files that won't necessarily
be true (uses old format).
Any objection to writing it in C using the sites
API? Hardest part would be writing the rules parser and setting
up the look-up table, but both r.reclass and v.reclass should
have code that does that already....
Eric G. Miller <egm2 at jps.net>
