[GRASS5] [bug #879] (grass) s.reclass: obviously not working
Andrea Aime
aaime at comune.modena.it
Wed Dec 19 03:19:50 EST 2001
Wouldn't it be possible (and better) to include routines involved
in parsing and execution of reclass in a library to avoid
source code clones? Just a suggestion, maybe we should just
fix s.reclass/v.reclass now and deal with the library thing
as a part of the library reorganization envisaged for grass5.1
Best regards
Andrea Aime
"Eric G. Miller" wrote:
> On Tue, 18 Dec 2001 18:37:17 +0100 (CET), Request Tracker <grass-bugs at intevation.de> wrote:
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=879
> > Subject: s.reclass: obviously not working
> > Hi,,
> > any awk guru out there?
> > Today I tried s.reclass with no avail. Neither
> > 1 2 3 4 = 1
> > nor
> > 1 thru 4 = 1
> > nor
> > 1 = 2
> > rule is accepted.
> > I remember that the script was working once...
> > The awk-based script is in
> > src/scripts/contrib/s.reclass
> > Perhaps worth a fix,
> > thanks
> > Markus
> > PS: I have at least improved the cmd line "parser" today...
> It makes some assumptions about sites files that won't necessarily
> be true (uses old format).
> Any objection to writing it in C using the sites
> API? Hardest part would be writing the rules parser and setting
> up the look-up table, but both r.reclass and v.reclass should
> have code that does that already....
> Eric G. Miller <egm2 at jps.net>
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
