[GRASS5] [bug #880] (grass) Can't start monitor on latest cvs
 (19/12/2001)
    Andrea Aime
    aaime at comune.modena.it
    Thu Dec 20 08:20:46 EST 2001
Just to make sure, I checked out again in a fresh directory:
export
CVSROOT=:pserver:grass-guest at intevation.de:/home/grass/grassrepository
cvs login
cvs -z3 checkout -r releasebranch_11_april_2001_5_0_0 grass
I deleted the old install directory /usr/local/grass5, deleted
$HOME/.grassrc5, made configure (with the same problems reported in bug
802),
make, make install and the problem is still there...
can anyone with a RedHat 7.2 install try the same?
Sigh, it worked with my first install, when I checked out GRASS two days
ago...
Best regards
Andrea Aime
PS: is the any monitor related file that may haven't been deleted
while erasing /usr/local/grass5?
Andrea Aime wrote:
> I see the correct branch in the CVS/Entries file, anyway I updated
> again my cvs copy with
> cvs update -r releasebranch_11_april_2001_5_0_0
> cvs up -dP
> as suggested on the GRASS web site, just to make sure I haven't
> overlooked anything, and compiled again... same problem.
> See also my configure problem in bug 882.
> This evening I will check how it works at home on my Mandrake box.
> Best regards
> Andrea aime
> Andreas Lange wrote:
> > Hi,
> > Request Tracker wrote:
> > > this bug's URL: http://intevation.de/rt/webrt?serial_num=880
> > > Subject: Can't start monitor on latest cvs (19/12/2001)
> > > Platform: Linux/Intel
> > > Linux distro: RedHat
> > > linux cpu: Intel (i486, i586, pentium ...)
> > > Xwindows version: Xfree 4.0.x
> > > Xwindows manager: KDE 2.x
> > > TclTk version: tcl/tk 8.3
> > > grass downloaded at: CVS Server, Germany
> > > grass binary for platform: I compiled the sources myself
> > > grass sources source: yes, I am using the latest GRASS from CVS
> > > d.mon reports the following error:
> > > d.mon start=x0
> > > Could not execute monitor: No such file or directory
> > > No socket to connect to for monitor <x0>
> > It works here (at least 1 minute ago...).
> > Are you on the wrong CVS branch?
> > The main branch is not working, development is on the
> > "releasebranch_11_april_2001_5_0_0", check here for more details:
> > http://grass.itc.it/grasscvstags.html
> > HTH,
> > Andreas
> > Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
> > url: http://mitglied.tripod.de/AndreasLange
> > mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
> > grass5 mailing list
> > grass5 at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass5
> grass5 mailing list
