[GRASS5] [bug #880] (grass) Can't start monitor on latest cvs (19/12/2001)
Markus Neteler neteler at itc.it
Thu Dec 20 08:57:19 EST 2001
On Thu, Dec 20, 2001 at 02:20:46PM +0100, Andrea Aime wrote:
> Just to make sure, I checked out again in a fresh directory:
> export
> CVSROOT=:pserver:grass-guest at intevation.de:/home/grass/grassrepository
> cvs login
> cvs -z3 checkout -r releasebranch_11_april_2001_5_0_0 grass
> I deleted the old install directory /usr/local/grass5, deleted
> $HOME/.grassrc5, made configure (with the same problems reported in bug
> 802),
> make, make install and the problem is still there...
> can anyone with a RedHat 7.2 install try the same?
> Sigh, it worked with my first install, when I checked out GRASS two days
> ago...
> Best regards
> Andrea Aime
> PS: is the any monitor related file that may haven't been deleted
> while erasing /usr/local/grass5?
Andrea,
that's really strange. Please check following:
the d.mon socket files are stored in
/tmp/grass-$USER
do you have write permission there?
Just a guess,
 Markus
> Andrea Aime wrote:
> > I see the correct branch in the CVS/Entries file, anyway I updated
> > again my cvs copy with
> > cvs update -r releasebranch_11_april_2001_5_0_0
> > cvs up -dP
> > as suggested on the GRASS web site, just to make sure I haven't
> > overlooked anything, and compiled again... same problem.
> > See also my configure problem in bug 882.
> > This evening I will check how it works at home on my Mandrake box.
> > Best regards
> > Andrea aime
> > Andreas Lange wrote:
> > > Hi,
> > > Request Tracker wrote:
> > > > this bug's URL: http://intevation.de/rt/webrt?serial_num=880
> > > > Subject: Can't start monitor on latest cvs (19/12/2001)
> > > > Platform: Linux/Intel
> > > > Linux distro: RedHat
> > > > linux cpu: Intel (i486, i586, pentium ...)
> > > > Xwindows version: Xfree 4.0.x
> > > > Xwindows manager: KDE 2.x
> > > > TclTk version: tcl/tk 8.3
> > > > grass downloaded at: CVS Server, Germany
> > > > grass binary for platform: I compiled the sources myself
> > > > grass sources source: yes, I am using the latest GRASS from CVS
> > > > d.mon reports the following error:
> > > > d.mon start=x0
> > > > Could not execute monitor: No such file or directory
> > > > No socket to connect to for monitor <x0>
> > > It works here (at least 1 minute ago...).
> > > Are you on the wrong CVS branch?
> > > The main branch is not working, development is on the
> > > "releasebranch_11_april_2001_5_0_0", check here for more details:
> > > http://grass.itc.it/grasscvstags.html
> > > HTH,
> > > Andreas
> > > Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
> > > url: http://mitglied.tripod.de/AndreasLange
> > > mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
> > > _______________________________________________
> > > grass5 mailing list
> > > grass5 at grass.itc.it
> > > http://grass.itc.it/mailman/listinfo/grass5
> > grass5 mailing list
> grass5 mailing list
