[GRASS5] [bug #884] (grass) r.water.outlet: obviously doesn't work properly
Request Tracker grass-bugs at intevation.de
Sun Dec 30 13:11:15 EST 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=884
Subject: r.water.outlet: obviously doesn't work properly
when running r.water.outlet the resulting map only contains a few
cells but not the watershed above this point. This module is
essential for any hydrologic and pollutant modeling...
Hopefully someone can have a look at this module.
Or is there any other method to get the watershed for a given
outlet?
Thanks in advance,
 Markus
-------------------------------------------- Managed by Request Tracker
