[GRASS5] r.cost
Glynn Clements glynn.clements at virgin.net
Sun Dec 30 23:22:33 EST 2001
I'd like to propose that r.cost be changed to eliminate the "dual use"
of the "output=" option, by adding a separate "start_rast=" option. If
none of the "start_sites=", "coordinate=" or "start_rast=" options are
given, an error would be generated.
Any objections?
Glynn Clements <glynn.clements at virgin.net>
