[GRASS5] developers list search engine available
Bob Covill
bcovill at tekmap.ns.ca
Fri Feb 23 13:39:08 EST 2001
Markus,
Just going throught the BUG list to see if I can help with anything.
r.in.bin - This uses G_scan_east and G_scan_northing to read input input
coordinates, so DD:mm:ss should work. I can update the html man page on this.
i.rectify - update history. It appears that i.rectify and i.rectify2 just copy
the original rasters history and do not make any changes. I will look at adding
a section to change the History structure accordingly.
Great to hear that NVIZ is working well for you with the new video upgrade. I am
curious to know if you are able to get a larger high resolution output with the
new tile dumping routines. Theoretically a higher end video setup should have a
larger OpenGL viewport. But I wonder if the max size is hardwired in OpenGL.
I think it is defined in gl.h?
Bob Covill
Tekmap Consulting
P.O. Box 2016 Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
Type: text/x-vcard
Desc: Card for Bob Covill
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010223/b1fc99ea/bcovill.vcf
