[GRASS5] Looking for ncurses code
Rich Shepard rshepard at appl-ecosys.com
Fri Feb 23 12:44:33 EST 2001
On Fri, 23 Feb 2001, Markus Neteler wrote:
> You can see CLI at work in src/raster/r.agnps50/ if you need an
> example.
  Again, thanks, Markus.
  I've grep'd the files in src/libes/vask/ and haven't found the names of
the variables used to store the input (GISDBASE. location and mapset). Is
there any guide in the programmer's manual to the organization of the start
up code and the user interface? I don't recall seeing that the last time I
looked.
  I'll look at the tcl/tk code, too, and see if I can find these variable
names there.
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
              Making environmentally-responsible mining happen. (SM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
 + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
