[GRASS5] Module file sizes
Rich Shepard
rshepard at appl-ecosys.com
Mon Feb 19 17:32:21 EST 2001
On Mon, 19 Feb 2001, David D Gray wrote:
> The module should be in .../grass5/etc/bin/cmd and make a hard link
> etc/front.end <-> bin/v.in.mif.
David,
OK. I moved v.in.mif to /usr/local/grass5/etc/bin/cmd. What is the proper
syntax for the link? `ln /usr/local/grass5/etc/front.end
/usr/local/grass5/etc/bin/cmd/v.in.mif'? Will front.end know about v.in.mif
specifically, or is it a generic pointer?
I'm getting close enough now that I don't want to mess up with the
incorrect syntax.
BTW, major bounds errors on the sample data. I'll send a separate message
on this.
Thanks,
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
Making environmentally-responsible mining happen. (SM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
