[GRASS5] vt100 error with osx + xterm error
John Huddleston
jhudd at lamar.colostate.edu
Mon Feb 19 16:12:04 EST 2001
Justin,
I get that same message using Cygwin. I checked the
/usr/lib/terminfo and all is well there. I'll look at the
initscr
John Huddleston
----- Original Message -----
From: "Justin Hickey" <jhickey at hpcc.nectec.or.th>
To: <grass5 at geog.uni-hannover.de>
Sent: Monday, February 19, 2001 12:34 AM
Subject: Re: [GRASS5] vt100 error with osx + xterm error
> Hi Andy
> andy agena wrote:
> > I should add that the 'vt100' error is when I 'grass5' in an Aqua
> > terminal. If I'm in a xwindows terminal via vncviewer, the error is
> > that it can't open 'xterm.'
> > Jeshua's binaries installed, but I get the following when starting
> > GRASS:
> > Starting GRASS ..
> > Error opening terminal: vt100.
> > Invalid resource file, removing /var/root/.grassrc5
> I don't think I can help much, but looking at the code, my guess is that
> the UNIX function initscr() (called within the vask library) is finding
> an error. This function exits the program if there is an error after
> printing a message (the "Error opening terminal:" message seems to be a
> UNIX message not a Grass message). I'm not sure, but it appears that you
> have a system problem as opposed to a grass problem. Anyone know more
> about the initscr() call and how it works with the vask library?
> Sorry I couldn't be of much help.
> Sincerely,
> Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
> High Performance Computing Center
> National Electronics and Computer Technology Center (NECTEC)
> Bangkok, Thailand
> People who think they know everything are very irritating to those
> of us who do. ---Anonymous
> Jazz and Trek Rule!!!
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
If you want to unsubscribe from GRASS Development Team mailing list write to:
